Clown Pass fragments
Started by scout144, June 09, 2016, 10:14:21 AM
scout144
We just updated to Keyshot 6 at work and we ran into an issue with some clown render passes. We are getting some fragments in the clown pass and render as well (see the attached image) that is not allowing a clean mask. Anyone experience this too?
Niko Planke
Hello Scout
May i ask what rendering mode you are using, and how the original scene look like?
I suggest to try to use Max Samples or Maximum Time as render mode.
Robb63
Hey Scout,
I was having this same issue a while back. Here's the thread....
https://www.keyshot.com/forum/index.php?topic=12225.msg59696#msg59696
Seems the issue in my case was not enough contrast between the edges of my object and the color behind it.
