Author Topic: Ribbed/Corrugated Pipe - Texture Map  (Read 5466 times)
Offline phatty70
« on: June 17, 2016, 12:51:16 pm »
Hello All!
I'm attempting to create a ribbed/corrugated pipe effect on a pipe.  Thefonzzz had a post about these a while back but I've been unable to get a texture to map on this pipe.
What is needed to generate this effect (see file "wanted.jpg" attached (which was shamelessly taken from the post from "thefonzzz" - hope nobody minds the reference))?
  • Guest
Re: Ribbed/Corrugated Pipe - Texture Map
« Reply #1 on: June 17, 2016, 02:23:25 pm »
what modeling software are you using?
Offline phatty70
« Reply #2 on: June 17, 2016, 02:40:58 pm »
Files are coming from Creo
  • Guest
« Reply #3 on: June 17, 2016, 03:06:47 pm »
Was afraid that would be the case. In order to properly texture the model needs to be uv mapped which is something we don't do yet inside KeyShot. There are other tools out there that allow you to do this. You would need to export to one of those tools - Rhino for example - uv map the object, and then import into KeyShot.
This is definitely something that we are looking to address in a future version of KeyShot.
Offline phatty70
« Reply #4 on: June 17, 2016, 03:12:20 pm »
Dag Nab It!  I'm looking forward to upgrade.  For the time being I'll revert to modeling the convolute (a painstaking process - especially when working with convoluted wireharness!)
  • Guest
« Reply #5 on: June 17, 2016, 03:45:04 pm »
Variable section sweep? Actually doesn't even have to be variable.
Offline phatty70
« Reply #6 on: June 17, 2016, 04:18:29 pm »
Typically I use a spinal bend in Creo.  Model Two convolutions - make an array - then bend with spinal feature to follow the curve.  I post results later.
  • Guest
« Reply #7 on: June 17, 2016, 05:17:32 pm »
Should look great.
Offline br3ttj
« Reply #8 on: June 18, 2016, 06:31:25 pm »
I'd definitely pay a premium for an extension or utility that could create and export UV maps from Creo and/or SolidWorks files, whether inside KeyShot or even as a third party software!  This would be very helpful for creating and wrapping complex textures as well as exporting files for full color 3D printing.
  • Guest
« Reply #9 on: June 20, 2016, 02:01:30 pm »
The most important thing is to keep it simple. We are looking into it.
Offline NM-92
« Reply #10 on: August 04, 2016, 12:19:06 pm »
Great to hear that !
