stripe artifact help
Started by ultima, July 12, 2016, 12:41:00 PM
DMerz III
Thanks for the suggestions, Niko.
From our experience; 1. and 5. were the best solutions for us.
Sometimes we can't change anything about the background color, and we have tried the Generate High Resolution HDR with no difference in the result.
Will try increasing the Anti-Aliasing in Advanced Control, as I could see that easily being the culprit.
sc4r4b
I wanted to take a moment to chime in and say that I have the same issue and the only fix for me is to utilize max samples.
designklitzsche
hi,
I have the same problem since using keyshot 6.
the stripes are in the clownpass too.
any solution?
thank you
nm
DMerz III
Try Max Samples if you can. It has helped clear this up for us in the past.
designklitzsche
hi,
unfortunately it doesnt helped.
it only takes more time.
I tried material, environment and samples. nothing changed..... :(
designklitzsche
hi,
I now tried anti aliasing to 5 > without stripes
hope it helpes somebody
DMerz III
Okay good to know!
I've never tried setting the anti-aliasing this high, will give a shot. Have you notice a significant increase in render times?
designklitzsche
in the model that I have tested, was no relevant increase of time.
hope this will be in more complex models too
