Author Topic: Adding Text to a Rendering  (Read 6879 times)
Offline Toddmichael
« on: August 01, 2016, 12:55:04 pm »
I am looking for a way to simply catalog rendered images, on the rendered image, so to identifiable for slideshow customers.
Toddmichael
« Last Edit: August 01, 2016, 01:01:07 pm by Toddmichael »
Offline NM-92
Re: Adding Text to a Rendering
« Reply #1 on: August 01, 2016, 01:42:41 pm »
Hi Toddmichael. Obviusly the easiest way to do this is to have a template in PS to throw your renders into after they are done. But if you want to do it within Keyshot for some reason, maybe you can design your frame or labels and set them as a backplate. Applying your part numbers as a label in the floor should work too. Hope it helps. Cheers.
