Author Topic: Axis on object  (Read 1780 times)
Offline PeterSwift
Axis on object
« on: August 10, 2016, 04:46:57 am »
Im rotating the green object then I'm gonna make a animation on the blue object as well using the green as pivot point. WHY does not the axis follow the green object?  Is just going though the center and is static.
Offline DriesV
  • Administrator
  • Total likes: 29
Re: Axis on object
« Reply #1 on: August 10, 2016, 06:14:46 am »
In this scenario results will be more predictable of you create a proper hierarchy. This means grouping/dragging the blue cylinder underneath the green one.
You can then animate the group, in order to rotate the pivot.
See attached example.
« Last Edit: August 10, 2016, 06:20:57 am by DriesV »
Offline PeterSwift
Re: Axis on object
« Reply #2 on: August 10, 2016, 06:27:19 am »
Thank you! So now I know it works. But Keyshot just dont updated the Axis when reselect it after or in a animation. Good to know!  Keyshot should fix that.
« Last Edit: August 10, 2016, 07:09:01 am by PeterSwift »
