Author Topic: Voronoi Fracture Animations and Stills  (Read 7296 times)
Offline Despot
« on: September 12, 2016, 08:35:51 am »
Been playing with Voronoi Fracture, the killer new feature of Cinema 4D R18... obviously rendered with KeyShot.
In KeyShot I used roughness and bump mapping on materials, ambient occlusion and motion blur
This is what I've done so far, much more to come. I've placed this in 'Amazing Shots' as I'm also uploading hi-res stills
Thanks for taking a look
Jon
« Last Edit: September 12, 2016, 08:59:31 am by Despot »
Offline Despot
Re: Voronoi Fracture Animations and Stills
« Reply #1 on: September 12, 2016, 08:37:02 am »
Here are a couple of hi-res stills... :)
Offline Josh3D
« Reply #2 on: September 12, 2016, 09:15:31 am »
These are great! That KeyShot ball one is trippy. The motion blur is perfect.
Offline DMerz III
« Reply #3 on: September 12, 2016, 11:24:11 am »
Wonderful, love the texturing as well. Is that bump/normal maps in Keyshot, or displacement maps from C4D?
Also, question for anyone, is there a video tutorial available for incorporating geometry like this from C4D and rendering in Ks6. I know there's a workflow incorporating scripts, but looking for a play-by-play tutorial to show me the way. (I'm a visual learner).
Offline Despot
« Reply #4 on: September 12, 2016, 01:37:13 pm »
Quote
Cheers Josh :)
Quote
Thanks man... it's all roughness and bump maps, no disp.
These animations were not exported as .fbx or alembic. Simply used 'Save project as Melange' from C4D and then opened in KS
  • Guest
« Reply #5 on: September 12, 2016, 02:31:59 pm »
Very cool!
Offline Despot
« Reply #6 on: September 13, 2016, 12:30:58 am »
Quote
Very cool!
Cheers Thomas :)
Offline Despot
« Reply #7 on: September 13, 2016, 12:36:59 am »
Here's another one, this time using the 'Inside Faces' feature which allows a different material for the 'shell' and the inner geometry...
Offline NM-92
« Reply #8 on: September 13, 2016, 05:22:16 am »
Saw the first ones in Artstation. Really fun to watch. I liked it a lot.
Offline Finema
« Reply #9 on: September 13, 2016, 07:02:03 am »
Really Nice John ! ;) I like it .
The rocks is using Voronoi Fracture also ? or Plugin Transform in C4D ?
Offline Despot
« Reply #10 on: September 13, 2016, 10:27:39 am »
Quote
Saw that Nico, thanks for the like :)
Quote
Cheers Philippe :) using Voronoi Fracture only, not GSG Transform. I think I also used the Delay Effector and the Vibrate Expression tag on the KS Ball anim
Offline Will Gibbons
« Reply #11 on: September 14, 2016, 07:21:53 am »
Ehh... it's pretty good.
I can't keep a straight face while typing that even, haha. These are awesome! I personally like the first one... the gold sculpture of the face. Using occlusion is smart there and seems to bring definition to each individual shard. Assuming you used it to emphasize the shadows in the cracks as it crumbled?
Offline LM6
  • Sr. Member
  • Total likes: 1
  • instagram.com/lm6_p | lm6-p.tumblr.com
    • LM6
« Reply #12 on: September 16, 2016, 01:24:30 am »
I've never tried the Melange route into Keyshot, going to try today, does the whole animation import to the Keyshot timeline?  I am guessing no deforms though?
Peter
« Last Edit: September 16, 2016, 01:26:09 am by LM6 »
Offline Despot
« Reply #13 on: September 16, 2016, 01:41:28 am »
Quote
You're right on both counts... when using 'Save project for Melange', all procedural motion, MoGraph etc is converted to keyframes, deforms though are ignored...
The only thing I've found that  doesn't work correctly using this export route is the Vibrate Expression. It wouldn't translate over correctly to KS, so I used NitroBake for that particular sequence.
Jon
Offline LM6
  • Sr. Member
  • Total likes: 1
    • LM6
« Reply #14 on: September 16, 2016, 03:30:29 am »
Thanks for the reply, so  if no deforms why not use fbx, is there a difference?
Peter
Quote
Jon
