Jagged shadows
Started by laurits12, January 08, 2011, 01:11:55 PM
laurits12
Hi
Does anyone have any suggestions/tips, on how to make Jagged shadows disappear? on building for example.....
Or did anyone See a tutorial some were on rendering building?
thanks laurits
KeyShot
The bip file you provided looks fine. There are two ways you can get better shadows. You can either increase the global illumination quality, or assuming that you are using 2.1 you can use the realtime rendering mode, which uses a different way of computing the shadows. There you will just have to use enough samples to get a smooth rendered image.
-- Henrik
laurits12
Now is working:-) i used the realtime rendering.
Thank you
