hey,im wondering why theres still a black screen out there.
Started by marty_yyz, November 13, 2016, 09:06:08 PM
marty_yyz
With an A graphic card AMD Radeon HD 8700m,quite out of time, though,I found it completely black while sending the model from Maya 2015 with the plug-in.Yet the insider keyshot file works perfectly.there's nothing wrong with the route,all English names.And I've already shut Graphics Effects bottom down in preferences.
Anyone in a similar situation?
LayC42
Hm, perhaps it's too early in the morning (06:30 am local time) - but I didn't understand the problem.
Can you update to the current version 6.2.105?
What effect causes the preference setting "graphic effects" to your scene?
Does the problem appear when you import the Maya model directly instead of using the plugin?
So we need some help to help you.
marty_yyz
sorry for knocking so early,it's actually afternoon here :).um...I've googled it a bit.As someone would choose to enter edit-preferences-advanced to shut this Graphics Effects off,so I did.yet didn't work it seems.the plugin version is 6.1.3
It could be that your camera is too close the geometry or inside it. Try changing the camera distance (mouse scroll) far enough out to where you see the environment dome.
aaah I see. Hit the "o"-Key to open the geometry editor. There you can change the view to perspective mode. Now you will see the active camera. Just check the attached Screenshot for detail infos. There is no difference between KS 6.0 to KS 6.2 by the geometry view.
hope that helps a bit.
cheers
