Label Problem
Started by quint_89, November 23, 2016, 08:22:55 AM
quint_89
I'm new to keyshot and have found it smooth sailing thus far. One odd thing is happening when i try to place labels on the model. There seems to be a round border to the label unless I shrink it down. This border changes depending on where I place the label. The attached images show what's happening, The only thing changing from image to image is either the scale of the label or the position.
The original model is from Solidworks. PNG image.
If you are using normal projection then you will need to adjust the depth. Increase the depth value until the late is no longer cut off.
quint_89
