Author Topic: Label disappears when material is changed  (Read 2056 times)
Offline luciel
« on: December 09, 2016, 08:28:23 am »
I have a model on which I've applied a material and a label. If I change the material, the label disappears and I have to reapply it again. Is there a way to have the label stay on the model even if you change the material ? I've included an example below.
Thanks.
  • Guest
Re: Label disappears when material is changed
« Reply #1 on: December 09, 2016, 08:34:59 am »
While dragging the new material onto the object, hold down the ALT key to keep textures and the CTRL/CMD key to keep labels.
You can see the notification at the top of the realtime window as well.
Offline luciel
« Reply #2 on: December 09, 2016, 10:20:17 am »
Thank you!
