Author Topic: White noise  (Read 8923 times)
Offline Zvi
White noise
« on: January 05, 2017, 02:09:53 am »
How can I solve this problem of white noise?
Offline Zvi
Re: White noise
« Reply #1 on: January 05, 2017, 03:43:47 am »
Another attachment
Offline Finema
Re: White noise
« Reply #2 on: January 05, 2017, 06:15:23 am »
Hi
have you try without Global illumination ?
Offline NM-92
Re: White noise
« Reply #3 on: January 05, 2017, 06:55:43 am »
In some cases, rendering in interior mode can help.
Offline Will Gibbons
Re: White noise
« Reply #4 on: January 05, 2017, 06:59:24 am »
Before your question can be answered, we need to identify the cause of the noise. If you can attach your scene as a .ksp file, it'll be easier to help. Do you have physical lights in this scene? What are your render settings?
Offline Zvi
Re: White noise
« Reply #5 on: January 05, 2017, 10:21:20 am »
Hi
Thank you, bu it didn't changed.
Offline Zvi
Re: White noise
« Reply #6 on: January 05, 2017, 10:23:49 am »
This are the settings.
Offline Zvi
Re: White noise
« Reply #7 on: January 05, 2017, 11:48:18 am »
Thanks a lot, it really helped, but  still remains some noise.
Offline Finema
Re: White noise
« Reply #8 on: January 05, 2017, 10:09:13 pm »
have you try to reduce Ray Bounces ? 50 is not necessary in your render
Offline Zvi
Re: White noise
« Reply #9 on: January 05, 2017, 11:44:37 pm »
The last attached image is in interior mode with only 6 Ray Bounces, and still there is white noise.
Offline Finema
Re: White noise
« Reply #10 on: January 05, 2017, 11:59:22 pm »
try to increase samples (32 or 64) in yours metal materials
Offline Zvi
Re: White noise
« Reply #11 on: January 06, 2017, 04:31:58 am »
I did so with 64 samples, and the white noise is still there, as you can see.
Offline Esben Oxholm
Re: White noise
« Reply #12 on: January 06, 2017, 06:37:55 am »
Do you use any emissive materials or physical lights in your scene?
Re: White noise
« Reply #13 on: January 06, 2017, 08:47:56 am »
Also, add some subtle roughness to your materials that are showing white spots, and make sure they have a material samples set to about 16. Your render samples should be good enough around 64. Make sure you have global illumination turned on. 10 Ray Bounces should be plenty.
Offline Zvi
Re: White noise
« Reply #14 on: January 09, 2017, 12:22:14 pm »
Not close to this noise.
