Author Topic: Flash animation export with transparency?  (Read 2333 times)
Offline Blumer
« on: January 06, 2017, 08:13:33 am »
I would like to be able to export a Flash animation that has transparency, so I can embed it into an interactive  PDF.
Is it possible to export a Flash animation with a transparent background from KeyShot?
Offline Will Gibbons
Re: Flash animation export with transparency?
« Reply #1 on: January 06, 2017, 08:53:54 am »
You can export frames as any file format that supports transparency (png will work fine), then load those frames into another software... however, standard video codecs don't support transparency. You could use a third party app to create an animated gif sequence (embeddable just like a jpg) that has a transparent background.
The shorter answer is no, not directly.
Offline Blumer
« Reply #2 on: January 06, 2017, 09:25:53 am »
Thanks Will.
I was reading upon interactive Pdfs and it seems like flash files are what is needed (darn). I have made animated gifs out of KeyShot before, I'll give it a go anyway...
