Furniture - tables
Started by Robertoo, January 26, 2017, 12:42:41 PM
Robertoo
HI :)
of my effects, please reviews
DMerz III
Very nice! thanks for sharing!
Quick tip, have you tried using a roughness map for the wood, this will vary the amount of 'shine' in different parts of the grain, and potentially give you an extra level of realism. Also, how are you achieving your lighting environment, are you using HDRI? Custom making one in the HDRI editor, or using any physical lights at all? I think the lighting is the next step to take these to the next level.
Some great images here. One main critique is that we're only seeing this furniture from the perspective of a cat... or ant. It's odd looking up at furniture since I'd normally never see it from that angle. also, I assume the top surfaces are well-lit... but that means the underside is not. If you wish to show off the lower/underside, I think the lighting could be improved.
