Author Topic: Animation Postproduction in After effect / using clownpass as a mask  (Read 4782 times)
Offline Ben J amin
I'm working on an animation. I rendered it in Keyshot, with clown (and depth) pass.
I added graphics etc in after effects. Now I want to brighten up a material - since I'm relatively new to AE, I thought it should be easy to use the clown pass, somehow track the color of the material, use it as a mask and brighten up that area.
Turns out it's not that easy (at least for me)
Did anyone ever do this? Whats the best way o do it? Any Ideas, Workaround or anything?
thanks in advance,
regards,
ben
Offline Esben Oxholm
Re: Animation Postproduction in After effect / using clownpass as a mask
« Reply #1 on: January 18, 2017, 07:25:15 am »
Hi Ben!
I think it should be possible to do it the way you describe.
However, the way I have done this is to  make a custom 'clown' pass.
I'll output the animation with all materials set to a flat black, except for the part I want to adjust. That part I'll assign a flat white material.
I then use this output as a 'track matte' for the adjustment layer in after effects.
Hope it makes sense to you. Otherwise just ask :)
Best,
Offline Ben J amin
« Reply #2 on: January 19, 2017, 08:42:50 am »
Hi Esben,
I actually thought about writing you directly about this problem, thank you for your answer!
I guess I'll do it your way, seems easyer.
I also had problems with the depthpass in AE, I could not solve them, so I rendered the DOF in Keyshot.
A tutorial of yours about the workflow in Keyshot+AE - especially with the renderpasses - would be so great! ;)
(you probably get a lot of requests like that)
thanks again,
Ben
PS: love your work!
« Reply #3 on: January 19, 2017, 11:54:30 pm »
Hi Esben,
thanks again,
Ben
PS: love your work!
Ha, that is great.
Thanks for the nice words.
It's very rare that I use renderpasses when working with animations. I think the case I'm referring to is the only time I've done it.
However, a KeyShot --> AE tutorial is not a bad idea :)
Let me know if you were able to solve your problem.
Offline Ben J amin
« Reply #4 on: January 20, 2017, 04:23:20 am »
Hey,
yes, I were.
Your approach was the solution. Pretty straight forward ones you rendered the "mask".
I'll post the animation, once it is released.
One thing about the depthpass - think about doing DOF in post: no re-rendering, if something is out of focus, everything is adjustable, so much more possibilities ;) I have to get this to work...
thanks again,
Ben
« Reply #5 on: January 20, 2017, 05:12:14 am »
Hey,
yes, I were.
thanks again,
Ben
Yeah, great quality DoF in post would be nice.
I haven't managed to get anything as great the DoF from KeyShot. Let me know if you manage to get some great results :)
