Material Boolean Animations: WIPs
Started by bdesign, January 22, 2017, 07:44:16 PM
Esben Oxholm
Quote from: Will Gibbons on September 06, 2017, 09:02:51 AM
Quote from: Esben Oxholm on September 05, 2017, 11:01:21 AM
Quote from: Will Gibbons on September 05, 2017, 08:41:36 AM
Is anyone sure it was animated in KeyShot? hahaha
Ha, that is a good point. It is just that he says that it is a material based boolean. Would love to see that ksp!
If only rendered in KS, maximum troll level will have been reached.
Ha, indeed!
Quote from: MWo on September 06, 2017, 10:53:05 AM
I played a lot but can't find the right material graph setup combining the nodes. It has to do something with emissive material and the right label material and the backside surface mask in the transparency channel or maybe an occlusion.
I try to send a PM to Eric Brock the master nut cracker ninja.
Sounds like what I've tried as well. Emissive, backside surface mask and opacity stuff.
I hope he gets back to you!
bdesign
#16
yes...someone is sure...hahaha. FFS
LayC42
Quote from: bdesign on December 21, 2017, 11:10:26 PM
Woah! Return of the Jedi here. Nobody has been able to figure this out.
