Author Topic: 1914 Lewis Gun - Aircraft version  (Read 2600 times)
Offline HuwBThomas
« on: May 14, 2017, 05:03:49 pm »
Modelled in Fusion 360, so it could be 3D printed.
Render of the printing file - hence some splits down centerline - which I can fix.
Love the curvature procedural for 'roughing' it up!
Enjoy, Huw
« Last Edit: May 16, 2017, 03:49:00 pm by HuwBThomas »
Offline mattjgerard
Re: 1914 Lewis Gun
« Reply #1 on: May 15, 2017, 05:30:16 am »
Very cool!  Is this a model of a real thing, or is this an imaginative piece?
Offline HuwBThomas
Re: 1914 Lewis Gun
« Reply #2 on: May 15, 2017, 06:23:06 am »
Hi Matt, Thanks.
It was modelled for a local air museum in Kansas, so I tried to be as accurate as possible - modelled mainly from technical drawings, with some references to photos etc. Its the aircraft version, so does not feature the barrel shroud.
The only main area I took some liberties on, was the mount (as the gun is mounted onto an aluminum bar,  supported by a 'tee' piece joint).
Therefore, the aircraft mounting part (with 'THOMAS' and '2017' is an approximation of the actual mount used. Its pretty close though...
The actual aircraft is shown here, with both the Lewis Gun and the engine (which I also modelled and 3D printed)
http://combatairmuseum.org/aircraft/aircodh2.html
Regards, Huw
« Last Edit: May 16, 2017, 03:48:32 pm by HuwBThomas »
Offline TpwUK
Re: 1914 Lewis Gun - Aircraft version
« Reply #3 on: May 21, 2017, 02:06:58 am »
Excellent modelling and super renders.
Offline HuwBThomas
« Reply #4 on: May 21, 2017, 12:10:38 pm »
Thanks for your kind comments, Martin!
Regards, Huw
Offline TGS808
« Reply #5 on: May 21, 2017, 12:19:09 pm »
I'm guessing the actual gun didn't have a KeyShot logo embossed on it.  ;)
