cross fade from 2 objects
Started by designklitzsche, May 18, 2017, 12:29:36 AM
designklitzsche
hi,
It is possible to produce a cross-fade from one part to the other.
I tried it by fade out one part from 100 to 0% in 2seconds. in the same time I fade in the other object from 0 to 100%.
It doesnt worked. there were many artefacts..
thanks
LayC42
The artefacts appears if both object uses the same space. Try to scale one part to 0.99 % or 1.01 %
Hope that helps
mattjgerard
^^^ That's the answer. I've tried this before as well, and this is the solution that worked. There might be other factors, if you can post some screenshots or a project file we can take a deeper look.
designklitzsche
hi,
thanks for the hint. It works  :)
