Author Topic: Assembly Rubik  (Read 1671 times)
Offline zooropa
Assembly Rubik
« on: May 18, 2017, 01:33:02 pm »
Hi I am doing a presentation for my school. It is the last project so I will like to have a nice animation of my rubik cubic turning and assembling.
The idea is to show the pieces. I was wondering if there is any way to move the rubik modules in keyshot in order they follow a guide.
Please find attached a screenshot of the model 'exploded' in rhino. I would like to get this result, but from the rubik cube assembled.
Thanks so much
Offline LayC42
Re: Assembly Rubik
« Reply #1 on: May 18, 2017, 10:29:25 pm »
Guiding lines are not supported yet.
If I would animate this explode state, I would start in the assembled state. Then dis-assemble the different parts with KeyShot animation features. Group all in a folder and mirror this. Now you got an assemble animation.
Maybe you can share your results?
Offline zooropa
Re: Assembly Rubik
« Reply #2 on: May 19, 2017, 01:25:56 am »
Thanks. So if I understood right:
You will animate it when its a 'cube' and the move away the parts manually?
Ok I will see how I can solve this, cause I do not know manually how to arrange so many different objects symmetrically /
Please finde attached a test of the final stage how I want to be seen.
Thanks a lot
Offline INNEO_MWo
  • Total likes: 6
Re: Assembly Rubik
« Reply #3 on: May 19, 2017, 06:14:16 am »
I like this animation! And I'm sure that if you measure the end point of the path in rhino you'll see that you've got only a handful of (positive and negative) values in a simple matrix.
This shouldn't be so complicated! It's just about grouping the parts in a logical order like Richard did with the hinges (https://blog.keyshot.com/animating-hinges-with-multiple-pivot-points-keyshot)
Hope that helps
