Noise in the picture
Started by Jan, May 22, 2017, 12:53:15 AM
Jan
Hello, I have some noise in the picture. What is it?
Are you using physical lights in the scene?
Jan
No, there is only light from the environment.
Can you share the scene? Send to me via keyshot.wetransfer.com.
And also, what version of KeyShot are you using?
IMHO some simple steps would reduce this.
- uncheck global illumination and caustics
- reduce ray bounce to 2 or 3
- don't use any glow effect
- zoom to the area with the effect and let the live render run for a while
  - If this solved the issue use max sample mode for render. The heads up display will give you hints for the right value. Or use a max sample rate of 250 and stop the render if you're happy.
And if this doesn't help, change the sample value from the material.
Hope that helps
