When Importing a 3dm file, Keyshot opens a new file
Started by jpits11, May 31, 2017, 07:06:39 PM
jpits11
Hi All,
I'm using Keyshot 6.3 and I'm having this issue. I have a Keyshot scene set up with environment and lights and I need to import files in this particular file in order to render consistently.
But when I import a 3dm file, it gets imported in a new Keyshot untitled file. But I need the original file to import more objects and render.
Is there any possibility of importing a 3dm element into the same Keyshot file?
INNEO_MWo
Can you share a screen grab of your import dialog?
jpits11
I ssume? no I'm not using any plugin. how can I find it?
This dialog shows the import of a new file. When you import another file into the scene, you will have the option to "add to scene".
jpits11
Does it mean I must have an object into the scene to get that dialog>
If you already have an object in the scene then the dialog looks slightly different.
jpits11
Ohh I get it. So how can I do when importing from a script?
