Paste linked material to group
Started by ROS, June 16, 2017, 06:59:55 AM
ROS
Hey guys....It would be nice and helpful to have a new feature --> Paste linked material to group by shortcut (e.g. SHIFT+ALT+RMB)
Thanks a lot  ;)
ROS
This enhancement would be very helpful if i apply a material to a model an copy / paste linked material in the realtime view.
The problem is that very often companies use coloured thread.
I always select the model in the realtime view and paste linked material to one level higher in the scene three but this is not very fast.
That's the reason i want a shortcut for paste linked material to group (one level higher) in the realtime view.
I hope this explains it a little bit better
If there are some better ways to do that please let me now.....Thanks
Or make the LMB+SHIFT and RMB+SHIFT work in the scene tree. that would be totally awesome.
You can select the objects in the scene tree, and then go into the "inproject materials library" and drag and drop the desired material onto the selected objects. That will link them all together.
