Rendering size and UI dont hold
Started by jeffw, March 21, 2011, 12:23:06 PM
jeffw
I am seeing two inconsistencies in Keyshot and wondering if someone with dual monitors could make a test to see if what happens to me is a local issue or a bug. They are the Keyshot UI does not remember its UI and rendering size. Here is my M.O.
1. Open Keyshot and go full screen using 'f' key
2. Open a .bip from 'open recent'
3. In render options set print resolution height to 4.5 inches. Width is determined by keep aspect ratio. dpi at 300.
4. Save file, run the render and exit Keyshot
5. Re-open Keyshot and the UI is no longer full screen.
6. Go to render options and the hieght is now 4.497 or .003 less.
This happens for all files. Not a huge deal but rather irritating to have to not be able to have a re adjust this every time you open a Keyshot file.
Hi jeffw,
I went through your steps with my dual monitor setup and my render output size stayed at 4.500 when opening again. Not sure what would cause your issue.  ???
Chad
jeffw
Thanks for testing it. Perhaps the rendering size issue is local to my setup. Could you say if your
UI re-opened full screen after closing it full screen?
Jeff
No problem.
I didn't think it did, so just tried it again to confirm - it doesn't re-open full screen after closing full screen. It's close though but not maximized completely.
