Author Topic: WIRE doesn't contain geometry. Issue with different versions of Keyshot.  (Read 6201 times)
Offline alco3d
Hi there!
I don't use KS about 3 years but clearly remember I worked with .wire without any problem before. Now I try import my different .wire files (fresh and old) on two different Keyshot versions - licensed 6.3.23 (C:/) and trial 4.3.18 (D:/) with different import option, but everytime I get "file doesn't contain 3d geometry."  I try placed .wire in both disk but I get the same. Alias Studio version 2016.
« Last Edit: June 30, 2017, 04:10:44 pm by alco3d »
Offline alco3d
OK, I solved that! It was a problem with installing .wire files in the system. Update Alias Studio by SP1 is helped.
Offline LayC42
Thank you for the hint to the solution.
