Author Topic: Liquid turns black on black reflective ground?!?  (Read 4000 times)
Offline alexjones
« on: July 25, 2017, 07:59:16 am »
Hello ,
 I would like to make the liquid the same color as if I put the model on white ground.
Alex
Offline INNEO_MWo
  • Total likes: 12
Re: Liquid turns black on black reflective ground?!?
« Reply #1 on: July 25, 2017, 10:23:16 am »
Did you use a glass material as the ground material? Then try the ground mat with full reflection and use the product lighting present.
Offline alexjones
« Reply #2 on: July 25, 2017, 12:03:12 pm »
Thank you MWo, unfortunately I was not able to get it to work, I am attaching the file, would you mind showing it to me please?
Alex
  • Guest
« Reply #3 on: July 25, 2017, 12:37:00 pm »
Select "Product" lighting mode in the Lighting tab.
Offline alexjones
« Reply #4 on: July 25, 2017, 02:00:06 pm »
It worked ,
Thank you thomasteger
