Liquid turns black on black reflective ground?!?
Started by alexjones, July 25, 2017, 07:59:16 AM
alexjones
Hello ,
I would like to make the liquid the same color as if I put the model on white ground.
Alex
INNEO_MWo
Did you use a glass material as the ground material? Then try the ground mat with full reflection and use the product lighting present.
alexjones
Thank you MWo, unfortunately I was not able to get it to work, I am attaching the file, would you mind showing it to me please?
Alex
Select "Product" lighting mode in the Lighting tab.
alexjones
