Author Topic: Help with texture recreating  (Read 4404 times)
Offline satrius
« on: August 02, 2017, 06:54:41 am »
Hi All,
I am new here and I am newbee as a Keyshot user. There is a pattern i need to recreate on a plastic material and I don't know how. I read through internet and am supposed to do it via 'Textures' - bump maps but for some reason i cant make it work. I tried going through few video lessons on youtube but I couldn't do it. Please see the attached image. Any suggestions are welcome, links to tutorials too. :)
Thank you in advance!
https://ibb.co/nETcn5
or
« Last Edit: August 02, 2017, 06:58:48 am by satrius »
Offline satrius
Re: Help with texture recreating
« Reply #1 on: August 02, 2017, 09:52:55 am »
On second thoughts. I wasn't clear enough.
I have a temp solution. I am using a PNG pattern applied to the Textures-Bump. The problem is it is an external file that may get lost (due to S drive changes etc.) and I was looking to find a way to recreate it by using only keyshot's resources.
Offline LayC42
« Reply #2 on: August 04, 2017, 12:32:56 am »
Do you ever played with procedural textures?
Try'em in KeyShot 7. The new types should help you creating this.
Or maybe you'll attach a sample file so that the community can play with and reply solutions?!
Hope that would help to find the answer(s).
Offline Esben Oxholm
« Reply #3 on: August 05, 2017, 05:04:23 am »
Hi Satrius.
Here's a quick setup. Not perfect, but might help you in the right direction.
Download KSP here: https://we.tl/Tc4Sjs7wy9
Best,
Online designgestalt
« Reply #4 on: August 08, 2017, 07:06:35 am »
hello Esben,
good approach ...
not trying to tease you, but there is some irregularity in the size of the pattern shown in the examples. they look like some kind of fabric.
is there a way to mimic that with the procedural texture (i.e. put some kind of randomness into the size of the squares)
thanks upfront!
cheers
designgestalt
« Reply #5 on: August 09, 2017, 07:43:28 am »
thanks upfront!
Good catch, Dirk. I noticed that as well, but couldn't find a way to drive a random distance between the lines.
Maybe it can be approach a different way that allows to do it. :)
Offline NM-92
« Reply #6 on: August 09, 2017, 03:36:09 pm »
Hi Satrius.
Best,
Esben, applying the same procedural into the specular channel can also help to simulate some "depth" in the bump when the bump height is not enough. Not sure if necessary in this particular case or if you already knew, just adding a tip to your solution. Cheers !
