Author Topic: Problem with importing multiple configurations parts (SW2017, KS6)  (Read 3631 times)
Offline malf
If i have a part with more one configuration and in an assembly there are several instances of this same part each in different configuration, big mess when i import in Keyshot. Only one instance is imported, others simply ignored. I have to rename each part in Solidworks, save in different external files, open each and cancel other configurations. Same big problem with Toolbox hardware. Is that a bug?  Is it fixed in KS7?
Offline DriesV
  • Administrator
  • Total likes: 33
Re: Problem with importing multiple configurations parts (SW2017, KS6)
« Reply #1 on: August 04, 2017, 02:08:17 am »
Can you share your SOLIDWORKS assembly with us?
It would be great if we could have a look at your particular case.
Please send to <dries at luxion dot com> via https://keyshot.wetransfer.com/.
Which versions of SOLIDWORKS and KeyShot are you running? Are you using the plugin?
« Last Edit: August 04, 2017, 02:10:10 am by DriesV »
Offline malf
« Reply #2 on: August 04, 2017, 02:51:54 am »
keyshot: 6.2 stand alone, not plugin
solidworks: 2017 sp2
I make a new simple model. here it is https://we.tl/406S29zYOS
in solidworks serveral configuration
in keyshot only one imported
Offline DriesV
  • Administrator
  • Total likes: 33
« Reply #3 on: August 04, 2017, 02:55:26 am »
I can reproduce this issue when importing in KeyShot 6.
I then imported in KeyShot 7 using the same import settings and the model comes in perfectly, with all configurations of all instances.
When using the plugin, configurations of parts import fine in KeyShot 6 though. If you rely heavily on configurations, then perhaps the plugin is your best option, until you upgrade to KeyShot 7. :)
Offline DriesV
  • Administrator
  • Total likes: 33
« Reply #4 on: August 04, 2017, 02:58:44 am »
Also, the latest version of KeyShot 6 is 6.3.
You can download the installer here.
Offline malf
« Reply #5 on: August 04, 2017, 01:04:26 pm »
