Author Topic: (RESOLVED!) KS7 .434 missing most "Add Geometry" models  (Read 3881 times)
Offline Speedster
« on: August 07, 2017, 07:40:44 am »
Add Geometry shows only "Add Ground Plane", and the sphere, cube, ramps etc. are all missing.
« Last Edit: August 08, 2017, 07:47:26 am by Speedster »
Offline INNEO_MWo
Re: KS7 .434 missing most "Add Geometry" models
« Reply #1 on: August 07, 2017, 12:20:06 pm »
Just copy the files from KS6 resources folder "models" into the KS7 resources. The menu updates without restart.
The models folder can contain bip and obj files. And bip files can contain defined cameras instead of geometry.
Hope that helps.
« Reply #2 on: August 07, 2017, 12:29:37 pm »
All content is there. Make sure you run the full installer so you get all the new content: materials, HDRIs, models.
Offline Speedster
« Reply #3 on: August 07, 2017, 02:52:29 pm »
Quote
Make sure you run the full installer so you get all the new content: materials, HDRIS, models
I did run the full installer, as a clean install. I had uninstalled KeyShot 7 beta, and deleted all KeyShot 7 resources prior to the new install, as I always do. There was a problem in that KeyShot 7 could not locate the resources.  I had to go to Edit > Preferences > Folders and repoint each folder individually.  However, there's no folder for "Models" available on Edit > Preferences > Folders.
First screenshot shows that only the ground plane is available.
2nd shows the folders available.
3rd shows that the models do exist in the My Documents > KeyShot 7 model folder.  But I have no clue as to how to point to them.
Note that the KeyShot icon has been replaced with the Photoshop .psd icon, globally. This happened when I first installed the KeyShot 7 beta, and I cannot repair it.  Frustrating to say the least!  Any clues how to fix it?
« Reply #4 on: August 07, 2017, 03:10:29 pm »
You can edit the path to your resources.
Offline Speedster
« Reply #5 on: August 07, 2017, 03:53:56 pm »
Quote
Thanks, Thomas.  The problem is I have no idea what you mean!  I design medical devices, and know nothing about computers beyond the average user.  Can you guide me?
Thanks!
Online DriesV
  • Administrator
« Reply #6 on: August 08, 2017, 05:13:04 am »
Hi Bill,
Which users option did you pick when installing KeyShot? "Install for anyone using this computer" or "Install just for me"?
Could you try to uninstall and reinstall again using "Install just for me"?
If that doesn't work, then likely your power supply will explode. No, just kidding, then you should get in touch with support. :)
Offline Speedster
« Reply #7 on: August 08, 2017, 07:47:02 am »
Quote
Bingo!  That did the trick!  Not sure which option I used, but the "Install Just For Me" did it.  Totally clean install, all geometry intact, as is the entire Library., and all correctly pointed.
Thanks, Dries, as always!
Online DriesV
  • Administrator
Re: (RESOLVED!) KS7 .434 missing most "Add Geometry" models
« Reply #8 on: August 08, 2017, 07:49:29 am »
Excellent!
Kudos should go to our support guru Niko Planke for providing the golden tip. :)
« Reply #9 on: August 08, 2017, 12:44:50 pm »
What I meant was referring to the screen grab of the preferences you posted. "Resources" was pointing to C:\Users\Bill\... but your content was somewhere else. All you needed to do is edit that path. But I'm glad this is working now.
