Using more than one bump map on a material
Started by pauls, August 26, 2017, 11:49:15 AM
pauls
Hello,
I'm trying to create a more complex bump map on a material. Is there any way to layer / combine bump maps?
Thanks for any help you can offer.
INNEO_MWo
Do you ever played with the material graph and the different utility nodes?
Manipulating bumps comes with some limitations but you can combine 2 or more textures.
Esben Oxholm
Hi Pauls.
In this tutorial at 9:20, you can see how to add more than one bump map to a material using the material graph.
Hope it helps!
https://youtu.be/GhLY7U80A8Y?t=9m20s
pauls
That's a great tutorial and definitely is what I needed!
Thanks very much for your help.
Paul
Esben Oxholm
Quote from: pauls on August 31, 2017, 07:31:22 AM
Paul
That is good to hear!
Thanks, no problem.
