1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Data Import
Rhino
Importing Rhino file breaks object apart in surfaces
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Importing Rhino file breaks object apart in surfaces (Read 4611 times)
droman
Newbie
Total likes: 0
on:
September 02, 2017, 07:33:19 am »
Hi Everyone,
Does somebody also experience that when your import a Rhino file in the new Keyshot 7 it now breaks apart als the objects in to surfaces?
I don't you if this a new behaviour within Keyhsot 7 of dealing with objects within the parts tree? I personally find it not unusable when applying or changing materials on the objects. As will get a endless list of surfaces in the tree tab. Which is quite a pain to scroll through.
Hopefully this is something which can be turned of.
Thanks,
David
Logged
Administrator
Hero Member
Total likes: 62
Product Specialist at Luxion
Re: Importing Rhino file breaks object apart in surfaces
Reply #1 on:
September 02, 2017, 08:15:00 am »
This is a known bug with Rhino models. It is going to be fixed.
In the meantime, you can import with 'Import NURBS Data' checked. This will give you a single object in the Scene Tree.
Logged
FaccioDesign
Newbie
Total likes: 0
Reply #2 on:
October 27, 2017, 07:07:08 am »
Hi guys,
I've installed KS 7 in the last days and noticed when I import from Rhino with "import NURBS" checked I can't edit the rounded edges radius anymore at least on complex geometry.
It works very well if I export in OBJ and then import in KS but not directly with or without using the plug-in.
This morning I tried to import in KS a simple cube in .3dm format and rounded edges works, so I ended up could be a problem of complex geometry with loads of poly? Did you noticed something similar?
FD
Logged
Administrator
Hero Member
Total likes: 62
Reply #3 on:
October 27, 2017, 08:01:26 am »
Hi FD,
This is a known issue. A temporary fix for now, if you imported NURBS, is to Re-Tessellate the model/parts inside KeyShot (right click on part > Re-Tessellate). After Re-Tessellation, Rounded Edges will work again.
Logged
FaccioDesign
Newbie
Total likes: 0
Reply #4 on:
October 29, 2017, 04:38:39 am »
Hi Dries,
thanks a lot for you confirmation, I believed I was doing something wrong in the the new KS7 importing process.
FD
Logged
dr_tilo
Newbie
Total likes: 0
Reply #5 on:
December 02, 2017, 09:31:18 pm »
Hello Dries,
I am using KS HD 7.1.51 so I can not tessellate. Which workflow do you suggest for me in order to be able to work with the rounded-edges function in KS?
When I Import .3dm files into KS I get all objects broken apart into single surfaces and therefore cannot apply the KS-function rounded-edges.
When I Export Rhino geometry to KS using the Plugin I obtain objects (not single surfaces) in KS but I cannot apply rounded edges and I also cannot tessellate with KS HD.
I read about the option of exporting as .obj from Rhino in order to obtain a file that is not broken apart into surfaces and that allows for applying rounded edges.
Kind regards,
Tilo
Logged
MK-ID
Newbie
Total likes: 0
Reply #6 on:
December 09, 2017, 10:56:26 am »
Hello guys,
I am experiencing the same problems since I upgraded from Keyshot 6 HD to 7 HD.
Imported Rhino files are only single surfaces instead of solids.
Usually I directly export Rhino files to Keyshot in order to maintain the structured layers wether for overview reasons or material applications.
Please fix this problem and send me/us your suggestions.
Thank you very much!
Logged
Print
Pages: [
1
Go Up
« previous
next »
KeyShot Forum
Data Import
Rhino
