Focus Question
Started by Little, May 11, 2011, 02:31:22 AM
Little
Hi!
I made this picture and noticed some strange near the front left wheel. Interesting focus.
I made some test renderings.
Is this focus correct?
This is my camera settings.
KeyShot
The focus in KeyShot depends on the distance to the object from the camera. This will be an ellipse if projected onto a flat plane as in your case. If you have a small focal length then you will be able to see the curvature of the region in focus. If you want to get closer to having a focus plane then you can increase your focal length. You can also use the perspective slider and readjust the focus point.
Little
Thanks for reply. I understand you very well.
This focus has given me some really interesting results.
Good luck!
