Author Topic: Switching Labels on a Material During An Animation  (Read 2725 times)
Offline TurfTracer
« on: September 14, 2017, 10:20:07 am »
Is it possible to seamless switch from one label on a material to different label on the same material in an animation? I have tried adding the label as a video, but after I render I end up with a world of new problems (the labels flicker, move for some weird reason...all sorts of weird unexplainable things). Any help would be greatly appreciated.
Offline INNEO_MWo
  • Total likes: 6
Re: Switching Labels on a Material During An Animation
« Reply #1 on: September 14, 2017, 11:23:25 am »
Did you ever tried a colour fade in the opacity channel?
How quick does the switch should be?
Which KeyShot Version do you use?
Perhaps you can post your example?!
Offline TurfTracer
« Reply #2 on: September 14, 2017, 05:11:07 pm »
I have not tried a color fade in the opacity channel, but I will attempt that next!
The entire animation is only 6.5 seconds long...the first label is up for 3.5 seconds, then would (ideally) instantly switches to a second label for 1.2 seconds, and finally (again, ideally instantly) switch to the third label for 1.8 seconds.
I am using KeyShot Version 7.0.456
Unfortunately, at this time I am unable to post an example because it is of a product that has yet to launch.
Thanks Marco!
Offline INNEO_MWo
  • Total likes: 6
« Reply #3 on: September 15, 2017, 03:19:25 am »
Maybe this would help?!
Offline Niko Planke
  • Software Tester
  • Global Moderator
  • Full Member
  • Total likes: 1
  • QA-Lead, Luxion
« Reply #4 on: September 15, 2017, 04:02:21 am »
@TrufTracer,
You can send a Mail to [email protected], we can then set you up with a pre-release version that Includes fixes which might impact the outcome of you first attempt.
Offline TurfTracer
« Reply #5 on: September 15, 2017, 05:15:05 am »
Thanks Niko, I sent the e-mail a few seconds ago!
Offline TurfTracer
« Reply #6 on: September 15, 2017, 10:27:08 am »
[email protected] was able to help me resolve the issue within 24 hours...WOW! Seriously impressed with their level of customer support. Thanks again and keep up the great work!
Offline mattjgerard
« Reply #7 on: September 15, 2017, 11:13:47 am »
Can you post an example of your solution so it will be searchable in the forum?
