Author Topic: light noise/dots  (Read 8275 times)
light noise/dots
« on: September 18, 2017, 01:43:28 am »
Can anyone give me some help?
How can i remove those light dots in my render? maybe more time rendering? it took me 2hrs rendering so i think perhaps that is not the problem
The light is an Area Light Diffuse material
« Last Edit: September 18, 2017, 01:45:28 am by Bernardo Lickfold »
Offline designgestalt
Re: light noise/dots
« Reply #1 on: September 18, 2017, 06:02:53 am »
hello Bernardo,
I think it needs more time to cook...
try make an area render (i.e. of the lamp stand)and let it cook for a while and see what it does...
btw: rendertimes without the settings and the specs of your system do not say much ...
cheers
designgestalt
Offline INNEO_MWo
  • Total likes: 15
« Reply #2 on: September 18, 2017, 06:18:08 am »
Hello Bernardo.
Designgestalt is right. Let render run for a while. You can use the region to crop the render view port to this bulb area. Then let the KeyShot render it and wait till all dots are gone. You can see the sample rate you need in the heads-up display. Then you can render the entire scene with this value with the max samples mode.
Or use your current settings and render a resolution 1,5 to 2 times larger and shrink the picture in post. Then the dots were merged.
Turn of any effect settings like glow. 'Cause this would increase the representation of dots.
Nice bulb render so far!
« Reply #3 on: September 19, 2017, 01:13:47 am »
Thanks for the help guys, i really appreciate it
Offline INNEO_MWo
  • Total likes: 15
« Reply #4 on: September 19, 2017, 03:41:11 am »
And what steps solves your issue?
Please leave a note that other users would find it, if they search.
Thanks!
« Reply #5 on: September 19, 2017, 06:58:38 am »
sorry about that!
I use the region to define the quantity of samples i needed and them i rendered with the max samples mode.
but i also tested rendering with the same settings  like you said but with a higher resolution and shrink in post and it works too!
Offline cjwidd
« Reply #6 on: September 21, 2017, 01:11:22 am »
This webinar is very helpful regarding light materials and troubleshooting artifacts
32:21 - dots artifacts
44:35 - render settings
