KeyShot 2017 Render Competition Guidelines
Started by Josh3D, September 26, 2017, 10:27:24 AM
Esben Oxholm
Josh3D
Haha! That would be the 22nd. Thanks, Esben. Updated!
Benny L
Would it be alright to use third party textures? or all materials and textures have to be restricted to Keyshot 7's library?
Josh3D
Third party textures are fine to use. Would like to see some use of the materials along with them though.
Pouya Hosseinzadeh
Can i use a square ratio for rendering output?!
Such as 1920x1920 or 1080x1080 ??!
Josh3D
Hyncharas
I haven't been able to figure out how to render at a standard resolution; the values shift depending on the size of your interface, instead of being manually unlocked for both height and length.
Glen_Powis
#22
Hi, I have been trying to upload my submission multiple times and once it loads to 100% it goes back to a empty new topic screen. Any Help?
GP
Josh3D
@Hyncharas - you can set the real-time resolution on the Project Window, Image tab. When you go to Render, the Sill Image resolution will match the aspect ratio you've set in the Image tab. If you change W or H here, the other will update. You can also choose a preset.
@ Glen_Powis - How big is the file you're uploading. There is a 50MB limit. If you're uploading multiple, you may want to try one at a time. If you're still having trouble, just email them to web@luxion.com.
Thank you.
Hyncharas
Thanks, Josh.  Though I didn't have time to adjust it to a standard resolution last night, that information will be invaluable once I (eventually) purchase Keyshot - assuming I haven't won it in this contest, of course.
