settings of the scene
Started by DanieloDanielo123, October 21, 2017, 05:30:24 AM
DanieloDanielo123
Hello,
I have a problem with getting a realistic rendered interior effect. In attachments I present PrtSc with interior settings. I would be very grateful for your help :)
Can you please upload the scene the way you set it up? The attached scene in the KSP has only default materials assigned.
Thanks.
DanieloDanielo123
HI,
Thank you for your answer, in the attachment I send the scene.
Regards,
Daniel
DanieloDanielo123
I'm sending the correct format  :)
Thenks,
Daniel
I noticed that your walls are very shiny. Try dialing down the specularity.
DanieloDanielo123
I'm sorry but I do not understand what I have to do ?  ( Try dialing down the specularity ) ?
If you double-click on the material you will see that the Specular color of the plastic is set to all white. If you make it grey you will notice that it gets much less reflective.
