Author Topic: 10 days into animation render and machine crashed -- can I recover anything?  (Read 3800 times)
Offline Lenio
I'm hoping that the mp4 data was saved somewhere and I'll be able to keep what was partially rendered -- I'm on a Mac with Keyshot 7 Pro installed...
Offline Esben Oxholm
Hi Lenio.
Did you by any chance output as frames as well?
Offline ace cool
As Esben mentioned and what I know keyshot do is that first it will render all frames individually stored in a folder which is your output folder then it compiles all of them using an encoding script.
check if you have frames available then you can bind them manually as well.
Offline Lenio
Thank you for replying -- unfortunately, no, I did not save the frames with the animation at the start. I assumed it might add rendering time. Dumb move on my part. Besides the animation and rendering folders, does Keyshot write data anywhere? I know that Adobe software tends to write temp files for any of its video/animation apps, but in the case of Keyshot I can't seem to find anything...
Offline Will Gibbons
Unfortunately, you're out of luck here. I always render frames, then just compile them manually myself. Hard lesson learned I guess. Sorry to hear this happened!
Offline INNEO_MWo
  • Total likes: 23
There should be frames in the animation folder. Cause KS will delete them after merging the video file, if the checkbox for frames isn't checked.
Hope you'll find them.
And the tip  from Will is right. Render animations always with frames. You can delete them manually.
