Removing my queue renders
Started by Lei, November 14, 2017, 07:34:49 AM
Lei
Is there a way to remove all the queue'd images to be rendered on my queue without having to click Render>Queue, as this always results into crashing KeyShot, therefore i cannot remove or process the queue itself.
Long story short, I rendered an animation and there are frames which consist of black spots and dots therefore I listed all affected frames and trying to set up a queue render to render all affected frames. I believe i've set up around 27 images on queue, which caused my KeyShot to crash.
Thank you in advance,
Lei
sethcshort
You can delete the queue by going into your Documents/Keyshot 7 (or Keyshot 6) / Scenes folder and deleting the file: "q.xml"
The next time you open Keyshot the queue will be gone.
If it still crashes, try deleting any ".ext" and ".ext.geom" files you find there as well.
