Author Topic: XYZ Flipping when Import from 3ds Max Plugin  (Read 2594 times)
Offline Stevoid
« on: December 14, 2017, 03:48:31 pm »
I used the plugin for 3ds Max 2015 for a couple years now, and just recently (couple months), I have been having issues with my model coming in rotated incorrectly. It appears it is flipping the Y and Z axis when I import in using the plugin. I usually load pre-setup keyshot and 3ds "template" files each time before working on a new scene, so my file settings haven't changed.
Any ideas?
I also cant seem to find any settings for changing the axis on import. Right now I have to manually select the entire scene, rotate the objects and then snap to ground. Bit of a pain.
Any help would be appreciated! Thanks!
- Steve
« Last Edit: January 09, 2018, 03:37:20 pm by Stevoid »
Offline Stevoid
Re: XYZ Flipping when Import from 3ds Max Plugin
« Reply #1 on: January 09, 2018, 03:38:21 pm »
Checking back in on this in hope someone checks it out. Still going on and been really frustrating to have to manually rotate every time I send to keyshot. Thanks!
