Lighting box
Started by zooropa, January 30, 2018, 04:05:38 AM
zooropa
Hi. I am trying to set up a scene to render an exhibition panel/column.
My idea was to create the effect that occurs when a crystal medium gets illuminated from the edge.
You will probably saw this a lot of times when they illuminate acrylic panels from the side in stores.
Either to make the engraving in the acrylic glow.
https://www.google.no/search?q=acrylic+light+edge&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjjr42K0v_YAhWBiaYKHWtMBmEQ_AUICigB&biw=1552&bih=1271#imgrc=7_JYviujsKAtTM:
I am trying to get decent settings for this scene. I activated the product mode and the caustics.
Another question is the paper "floating":  Should I use a doubled sided material for paper ? I gave a certain thickness, so I am not sure.
I am using an IES light (KS library) to get exactly the feeling that I want to achieve and see how it will behave in real life.
I need to build this afterwards thats the reason.
Please find attached the scene.
Thanks so much
I just split the outer edge and applied an emissive material. You could more closely match your reference photo by using a cloudy plastic for the acrylic.
My way is the fast-to-render quick and dirty method.
zooropa
This is a great trick! Great thanks a lot
