Author Topic: Wire file items from hidden layers importing  (Read 7849 times)
Offline sn
« on: February 07, 2018, 03:02:45 pm »
Keyshot v7.2: When I import a wire file with materials by shaders all items in hidden Alias layers are importing as well, this was not the case in previous version of keyshot, only visible items used to import. Am I doing something wrong or is this a bug?
« Last Edit: February 07, 2018, 06:04:39 pm by sn »
Offline Sean
Re: Wire file items from hidden layers importing
« Reply #1 on: February 09, 2018, 01:13:07 am »
I can't seem to reproduce this with a simple file. Would you be able to share an example? Can I ask how your import options are set, aside from "Group by Shader"? Are you using layer folders?
Which Alias version are you on, by the way?
Offline sn
« Reply #2 on: February 09, 2018, 10:30:17 am »
Alias Design 2018.4. Yes, I am using layer folders. Import settings are attached as jpg (see below) .
