HDRI editor output resolution
Started by terida, February 26, 2018, 08:49:35 PM
terida
Background in environment menu,  If I select Color or  Gradient or Sun&Sky,
I can select resolution preset  what I want.
But, when I select "Image",  I can't export HDRI more than 4000px*2000px resolution even the original image is larger than 4000px width and displayed resolution is correct.
Is this bug?
Does anyone have same problem?
I really want to know how to output higher resolution HDRI.
Platform / OS : windows7 64bit
KeyShot version :7.2.135
This works fine for me.
If I load a 10000x5000 HDRI and export it again from the HDRI Editor, then that new HDRI is also 10000x5000.
I can't replicate this issue as well. I created a new scene with a new environment. Set background to sun & sky with 10,000 x 5,000 px. Added a pin. Recalculate the resolution and exported it as .hdr file (see attached).
Done is current version of 7.3
terida
thank you DriesV and MWo.
but still I can't export HDRI lager than 4000px, even if I load big HDRimages..
ummmm
terida
I upgrade keyshot8, but still I can't export HDRI lager than 4000px.
This time I notice that if I add  a pin, the export resolution go down to 4000px X 2000px.
Does anyone have same issue?
Best to start posting screen shots of your environment settings, your export settings, create a simple project, save it as a package and post that too.
Just a thought, would this be a limit to the trial or student version of keyshot?
