Combining Two Opacity Maps
Started by Jikkk, April 29, 2018, 02:25:27 AM
Jikkk
Hey, everybody!
How to combine two (or more) opacity maps? I've been experimenting with the Color Composite node with all types of Blend Modes but nothing worked.
Hello Jikkk.
I guess you're on the right track.
What are the resources for the composite node?
You can also combine several procedural textures.
Or use a color to number node between the composite node and the opacity channel.
If you tell us which version of KeyShot do you use, I can post an example.
Jikkk
Hey!
My inputs are two Mesh textures with different setting (Circular and rectangular). I am using KeyShot Pro 7.2.
Yeah! Does it work as you expected?
Esben Oxholm
Hi Jikkk.
I just tried this out and can see that it at first behaves a bit differently than if you've used bitmaps.
I found that if you in each mesh texture change the alpha mode to 'opaque', then they will blend like regular bitmaps.
Let me know if it works for you.
Cheers,
Jikkk
Thanks Esben..
It now works like it should be. You're a Keyshot master!!!!  :)
Jikkk
Quote from: MWo on May 01, 2018, 02:53:11 AM
Hey Marco. Esben tip works. Thanks anyway!
Esben Oxholm
Quote from: Jikkk on May 01, 2018, 12:13:35 PM
Thanks Esben..
Great, good to hear!
Finema
Quote from: Jikkk on May 01, 2018, 12:14:57 PM
Glad to see, that this works.
It is a lil different if you write on a mobile phone or have an access to a system to test.
Esben's doin' right!!!
