Unable to load Keyshot7RhinoPlugin
Started by Adam Bucko, June 20, 2018, 03:13:25 AM
Adam Bucko
Rhino is unable to load Keyshot plugin (see attachment). Everything is up to date. Does anyone have a clue how to make it works?
,regards
Finema
Pierre G.
Same for me, except I use Rhino 5 and the previous plugin version (keyshot7_rhino_plugin_1.3.rhi)
Keyshot menu doesn't appear in the Rhino toolbar.
Pierre G.
Quote from: Pierre G. on July 09, 2018, 04:50:00 AM
I was wrong, Keyshot live linking appears as icons under the command line. It works !
Francisco
It appears that you could have an error with the installation of your KeyShot 7 plugin for Rhino 6. You will need to do 2 things that will help fix the error.
1. open your RegEdit window and go to "Computer\HKEY_CURRENT_USER\Software\McNeel\Rhinoceros\6.0\Plug-Ins\486807a0-d332-4669-8086-e0497d91acd5\PlugIn"
2. Modify the entry called FileName with information "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot7RhinoPlugin (486807a0-d332-4669-8086-e0497d91acd5)\1.6.0.0\KeyShot7RhinoPlugin\Rhino 5.0\KeyShot7RhinoPlugin.rhp"
3. Open Rhino 6 go to File >Properties > Plug-ins > then click Install and then go to "C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\KeyShot7RhinoPlugin (486807a0-d332-4669-8086-e0497d91acd5)\1.6.0.0\KeyShot7RhinoPlugin\Rhino 5.0\KeyShot7RhinoPlugin.rhp and choose the rhp file.
4. Restart Rhino 6 go back to the Plug-ins settings and make sure that KeyShot 7 plug-in is checked so it loads at startup.
