Printing Jewelry for Catalogue
Started by leohl1, June 25, 2018, 02:15:54 AM
leohl1
I am a beginner in Keyshot and would like to ask about printing.
my current setup is Keyshot 7 with Fuji Xerox Docuprint CP405D printer.
I am currently rendering jewelry such as rings and logos and would like to print it in a small dimension (4cm x 4cm for example).
my format is currently using PNG, with a DPI of 300-600.
With a 300 DPI, the resolution is around 600px x 400px and with 600 DPI, the resolution is around 1200px x 750px.
i have tried using different DPI around 300 and 600, using different resolution as high as 3840px x 2400px.
i am also using photoshop and coreldraw to adjust and print my renders.
The problem is, the quality of the print is not crisp and very blurry. i have tried using a regular A4, Glossy and Silky Photo paper but
have the same outcome, still very blurry and low resolution.
can you guys please recommend me a good render output for printing render images in small dimension with crisp and high resolution?
and what type of paper, or perhaps what type of additional settings should i add to make the image more crisp and high resolution?
Thank you.  ;D ;D ;D
I think you are getting confused about DPI and other factors.  To get a sharp image you really have to render large, then reduce to the target print size later in Photoshop.
For all of my client product renderings I set the render to 10" (3000 pixels) x whatever. These print great actual size, look great on an overhead projector or large monitor, and are easily resized for web or other uses.
In a few cases I set at HUGE output size, like 72" (21,600) to 120" (36,000) for stuff like trade show backboards.
Remember that when you drop a rendering into Photoshop, it will show up as 72 DPI.  Don't be misled!  Just "Resize" to 300 DPI, with "Resample" unchecked.
leohl1
Quote from: Speedster on June 25, 2018, 05:18:52 PM
Hi Bill G,
Thanks for your reply. by unchecking the "resample", i manage to get a very high quality print.
can you please recommend me a good paper to print jewelry in a very good detail?
Thank you!  ;D
Quotecan you please recommend me a good paper to print jewelry in a very good detail?
I do a lot of high quality giclee printing of KeyShot renderings, and highly recommend MOAB Lasal Exhibition Luster 300.  Luster is almost always the best choice regardless of brand.  I print now on an Epson P800 printer, which is absolutely awesome!  And reasonably priced to boot!
Robb63
Quote from: Speedster on June 27, 2018, 06:45:25 AM
QuoteLuster is almost always the best choice regardless of brand.  I print now on an Epson P800 printer, which is absolutely awesome!  And reasonably priced to boot!
I second Bill's suggestion. Luster paper looks amazing, and because it's not overly glossy you can see the details of the subject matter. I also second Bill's choice of printers. We've had the Epson P800 in my studio for a couple of years now, it produces amazing images and has been as solid as a rock. We bought it with the optional paper roll so we can print 16inch x up to 100ft images if needed.
