Hi there,
since Solidworks is using a coordinate system with Z up and and Keyshot a coordinate system with Y up, the models I send to keyshot with the plugin are rotated 90 degrees. I know that there is the possibility at the import dialog to set the up vector direction but this makes the plugin quite senseless. Do you plan to fix this issue ?
Best regards Markus
