Fairground lights
Started by Pernilla, July 27, 2018, 07:42:47 AM
Pernilla
Hi all! I trying desperately to get this light effect on my lightbulbs that should cast of a "star pattern" on the base. My (rhino) model has the geometric cut shape as the original Fairground bulbs.
Any tips massively welcomed!
Attached is a photo of how I want my results to be like.
#1
Hi Pernilla,
You will have to enable Caustics in the Lighting tab, in order to get the light pattern effect.
Make sure the base is a diffuse or plastic material (not a metal).
I can have a look at your model if you can share the data.
You can send data securely via our WeTransfer. Send to dries-at-luxion-dot-com.
