Author Topic: Welding - With textures & Tutorial  (Read 4843 times)
Offline Magnus Skogsfjord
« on: August 09, 2018, 05:10:25 am »
Hi guys,
So I've been in the ring a few times here trying to explain local UV mapping from CAD software, and I realized that it's not that simple to explain this in terms of written format. That's why I've decided to, for once, give back to the community and provide all of you interested a weld texture pack (4 actually) for free, as well as a walkthrough on how to use them.
To get a hold of these textures, visit the following link: https://gumroad.com/l/CADweld and type in weldme in the discount code to download it for free. This includes two .ksp's and 4 texture packs. I planned to put 0$ on this for gumroad, but there was suddenly a file size limit at 25mb on free products, so I had to do this workaround instead. But, it's still free, just remember to use that discount code! :) Oh, and let me know if you guys manage to use any of the textures. Would be great to see!
Anyway, the tutorial can be found here:
https://youtu.be/LpDFg1rh_nE
Below you'll find some work where I've used the different textues, all modeled in NX with no sculpting.
Cheers.
« Last Edit: August 09, 2018, 06:03:33 am by Magnus Skogsfjord »
Offline bdesign
Re: Welding - With textures & Tutorial
« Reply #1 on: August 09, 2018, 06:49:46 am »
This is outstanding, Magnus. A very professionally done, clear, and concise video tutorial. I've always been a big proponent of modeling with "flow" in mind. You explained it perfectly. The renders are beautiful, as always. Very kind of you. Thanks very much :)
Cheers,
Eric
« Reply #2 on: August 09, 2018, 07:26:45 am »
And a big thanks to you too Eric! I'm happy to hear that you think so :)
Offline Finema
« Reply #3 on: August 09, 2018, 07:46:18 am »
beautifull ! and thanks for the tutorial  ;)
« Reply #4 on: August 09, 2018, 09:04:53 am »
Thank you! You're quite welcome. Hope you find it useful :)
Offline scanner
« Reply #5 on: August 10, 2018, 06:31:41 am »
Many thanks Magnus! This tutorial and resources pack is very useful.
Offline Josh3D
« Reply #6 on: August 10, 2018, 08:56:37 am »
So good, Magnus! Thanks for sharing. Will be posting this on the blog!
Offline Will Gibbons
« Reply #7 on: August 10, 2018, 01:04:10 pm »
Killer! Hey Magnus, mind if I ask if you used specular or only roughness maps on the tubing of the first two hero shots? I love the look.
« Reply #8 on: August 10, 2018, 01:25:51 pm »
Cheers! Glad to hear it!
Awesome Josh! Thank you :)
Thank you Will! Hm.. It's a metal with roughness only (and a teeny tiny bump). As far as I know there's no specular on metals, right?
« Reply #9 on: August 10, 2018, 01:33:51 pm »
Yep! Wasn't entirely sure. But now that you point that out, of course, you're right.
Offline Hossein Alfideh
« Reply #10 on: August 13, 2018, 02:36:26 am »
Fantastic approach dude!I've been waiting to see the tutorial and high res images for so long!Bravo!
Offline INNEO_MWo
  • Total likes: 22
« Reply #11 on: August 13, 2018, 04:46:49 am »
Great and very helpful tutorial Magnus!
Have to give this a try with creo parametric files. (if I find some time to play)
Thanks a lot!
« Reply #12 on: August 13, 2018, 05:12:22 am »
Cheers Hossein! I'm so happy you liked it!
Thanks a lot!
Awesome! You're quite welcome. Let me know if you manage :) And thanks for your kind words!
Online Eric Summers
« Reply #13 on: August 13, 2018, 09:45:59 am »
Nicely done! That manifold looks so nice!
I use SolidWorks and was able to follow along with your tutorial pretty well. I did a little bit of testing of local UVs and had some success. I had issues at first, but once I turned on Render NURBS the UV mapping type worked as expected. Definitely have to be very conscious about how you model things to get a continuous face or surface. I never thought I could do this kind of UV mapping in SolidWorks. Thanks a lot Magnus!
« Reply #14 on: August 13, 2018, 09:53:10 am »
Cheers Eric! I appreciate it :)
I also greatly appreciate your feedback. Awesome that it works with SolidWorks as well, although it's strange that it only works in NURBS render mode for you, as it works in regular mode for me. Another thing that's strange is that I couldn't get it to work if I used the NX plugin to export it to KeyShot, but it works like a charm if I boot KeyShot as usual and import the necessary geometry.  Did you use the SolidWorks plugin for export/import?
