Author Topic: Animation Approach  (Read 2022 times)
Offline KJGDesign
Animation Approach
« on: August 29, 2018, 04:56:49 pm »
Hi Guys,
Can anyone offer some assistance or an approach further to my task below?
How would I go about animating a roll of aluminium foil, and rolling it out onto a floor such as the glue that is being laid in the below video? I only have keyshot to do this in.
https://www.youtube.com/watch?v=bGvGDYKNRck
 I haven't done it before but I'm thinking that if I use a strip on the floor of an intended path (with a material transitioning animation on it) and move a rotating cylinder over the floor quite close to the floor I can cover any material transition margin with this and have it appear as though it is rolling off the roll.
Am I on the right track? Does this sound plausible?
Any ideas would be much appreciated.
Offline Öner
Re: Animation Approach
« Reply #1 on: August 31, 2018, 04:33:49 am »
 Please look at the attachment file,  i hope i can tell you.  you should make all animation for all part at the same time, then repeat at for step 2, then step3 ...
Offline KJGDesign
« Reply #2 on: September 03, 2018, 04:36:39 pm »
Hi Oner,
Thankyou so much for your response, much appreciated and sorry for the delay in my reponse.
I ended up achieving the foil strip movement with a number fade and a colour gradient shift change, utilising the B/W gradient as an opacity mask with dual flooring layers similar to the below.
https://www.youtube.com/watch?v=37aas1iBRfY  (go to 39.50sec).
I'd show a short render but I am now having render problems with Keyshot maintaining (error!) my file at the end of an 8hr render...Ahhhh
Offline Öner
« Reply #3 on: September 04, 2018, 12:02:46 am »
hello, could you please show us your animation when you end up.
