material delete
Started by mrufo, September 03, 2018, 02:59:22 AM
mrufo
Hi
I am a beginner
If I happly a wrong material, I can found how to delete it (not happly a new material), I need to know if it is possible to delete o to come back
thanks
Max
Öner
open the project window bottom of the screen.  you can place it right side of your screen.  then double click on the material or surface which you add wrong material.  then go to the material on the project screen.  then go texture or label or what you want.  you can edit everything here.
