Author Topic: label moves when moving object  (Read 3018 times)
Offline malleyhub
« on: October 25, 2018, 01:32:49 am »
hi. i'm exepriencing this problem. after having applied a label to a material, when i move , rotate, etc the object, the label does not keep its position on the object (see images). any suggestion on how to block it? thanks a lot!
Online mattjgerard
Re: label moves when moving object
« Reply #1 on: October 25, 2018, 05:37:37 am »
can you post a screenshot of your scene tree? What sort of mapping for the label are you using?
Offline Will Gibbons
« Reply #2 on: October 25, 2018, 08:10:24 am »
What about if you change to 'global' axis instead of 'local' when in the move tool. That may work.
I would also check to see if your label is set to 'center on part' vs 'center on model'. If it's the latter and it's mapped onto another part that we can't see that's out of frame or hidden in the scene tree, that may explain the issue.
« Last Edit: October 25, 2018, 08:12:43 am by Will Gibbons »
Offline PhilipTh
« Reply #3 on: October 26, 2018, 01:46:04 am »
Hello malleyhub,
Would you be able to provide us with a .ksp for further investigation?
You may also send this through to support at [email protected]
To save a ksp file:
  • Open your scene
  • Go to File > Save Package
  • Name your file
